LMS 3.2.1: after upgrade to LMS321 : blank page after authentication
ebezombes
Customer has LMS 3.2.1 on win 2003 sp2.
After upgrating LMS 3.2 to 3.2.1, customer has a blank page after authentication.
Here you can find the link:
https://server_lms/CSCOnm/servlet/com.cisco.core.mice.main?command=initializeAndValidate&url=%2Fcwportal%2Fc%2Fportal%2Flogin&context=/cwhp&port=443
We have see bug CSCtb17186, we have verify registry value which are ok.
Help, it is critical,
Elisabeth
Vinod Arya
Share Stdout and stderr.log from NMSROOT/MDC/tomcat/logs.
Also, try the workaround for # CSCte29226 as well.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Thanks for your response,
For security reason I can't send you file.
I can see this error in :
[Wed Mar 13 21:02:18 CET 2013]loginpanel.jsp::service. Defaults to cwhp as 'URL' not found.
[Wed Mar 13 21:02:18 CET 2013]login::service. Checking for valid request.
[Wed Mar 13 21:02:18 CET 2013]*****************************************************
[Wed Mar 13 21:02:18 CET 2013]****** CsAuthServlet initialize: Wed Mar 13 21:02:18 CET 2013**
[Wed Mar 13 21:02:18 CET 2013]CsAuthServlet: Loading property file 'D:\CSCOpx\lib\classpath\md.properties'
[Wed Mar 13 21:02:18 CET 2013]CsAuthServlet: rootDir = 'D:/CSCOpx'
[Wed Mar 13 21:02:18 CET 2013]CsAuthServlet: Using AuthFile D:/CSCOpx\lib\classpath\com\cisco\nm\cmf\servlet\cwpass
[Wed Mar 13 21:02:18 CET 2013]CsAuthServlet: Loading property file 'D:\CSCOpx\lib\classpath\ss.properties'
[Wed Mar 13 21:02:18 CET 2013]CsAuthServlet: enable IP address checking
[Wed Mar 13 21:02:18 CET 2013]login::service. Checking for SSO configuration
[Wed Mar 13 21:02:18 CET 2013]SSOUtil::{static} Updating SSL port in SSO Properties
[Wed Mar 13 21:02:18 CET 2013]SSOUtil::{static} debug = false
[Wed Mar 13 21:02:18 CET 2013]SSOUtil::{static} login mode = 3
[Wed Mar 13 21:02:18 CET 2013]SSOUtil::{static} ASName = X.X.X.X
[Wed Mar 13 21:02:18 CET 2013]SSOUtil::{static} ASPort = 443
[Wed Mar 13 21:02:18 CET 2013]No login module switch.  Default: CiscoWorks Local
Loading module: com.cisco.nm.cmf.security.jaas.module.CsLoginModule
[Wed Mar 13 21:02:25 CET 2013]CsAuthServlet.loginUser: Redirecting to
https://X.X.X.X:443/CSCOnm/servlet/com.cisco.nm.cmf.servlet.CsAuthServlet?cmd=loginSuccess&id=E2B64EA9935CEA2BAF8392AE77B7628E&page=CSCOnm/servlet/com.cisco.core.mice.main?command=initializeAndValidate&url=/cwportal/c/portal/login&context=/cwhp&port=...
[Wed Mar 13 21:02:26 CET 2013]CsAuthServlet.loginSuccess: Page to redirection is CSCOnm/servlet/com.cisco.core.mice.main?command=initializeAndValidate&url=%2Fcwportal%2Fc%2Fportal%2Flogin&context=/cwhp&port=443
Log4j initialized = false
Inside initializeLog4j
Log4j initialized = true
[Wed Mar 13 21:02:26 CET 2013]CsAuthServlet.loginSuccess: Redirecting to page
https://X.X.X.X:443/CSCOnm/servlet/com.cisco.core.mice.main?command=initializeAndValidate&url=%2Fcwportal%2Fc%2Fportal%2Flogin&context=/cwhp&port=443
RM isValidReq decodedAddr is :  X.X.X.X
RM isValidReq remoteAddr is :  X.X.X.X
[Wed Mar 13 21:02:26 CET 2013] Error in handleCoreBaseRegistration within CMFExternal Servlet : java.lang.ArrayIndexOutOfBoundsException: 0 >= 0
[Wed Mar 13 21:02:26 CET 2013] 0 >= 0
at java.util.Vector.elementAt(Vector.java:427)
at com.cisco.core.mice.util.CMFExternal.handleCoreBaseRegistration(CMFExternal.java:694)
at com.cisco.core.mice.util.CMFExternal.receiveInitialCMFSessionData(CMFExternal.java:626)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.cisco.core.mice.CoreReflectionServlet.dispatch(CoreReflectionServlet.java:318)
at com.cisco.core.mice.CoreReflectionServlet.doGetOrPost(CoreReflectionServlet.java:163)
at com.cisco.core.mice.CoreBaseServlet.doGetOrPost(CoreBaseServlet.java:108)
at com.cisco.core.mice.CoreReflectionServlet.doGet(CoreReflectionServlet.java:75)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:627)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:659)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:457)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:395)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:311)
at com.cisco.core.mice.RequestManager.initializeCMFSessionData(RequestManager.java:361)
at com.cisco.core.mice.RequestManager.initializeAndValidate(RequestManager.java:215)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:172)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:775)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:704)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:897)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:662)
[ Wed Mar 13 21:04:10 CET 2013 ] TomcatMonitor After gettingAJPPort
[ Wed Mar 13 21:04:10 CET 2013 ] TomcatMonitor After gettingAJPPort : ajpPort = 9009 and host =DLM10002
[Wed Mar 13 21:04:16 CET 2013] Error in handleCoreBaseRegistration within CMFExternal Servlet : java.lang.ArrayIndexOutOfBoundsException: 0 >= 0
[Wed Mar 13 21:04:16 CET 2013] 0 >= 0
[Wed Mar 13 21:04:17 CET 2013]   isGateway= true
[Wed Mar 13 21:02:25 CET 2013]CsAuthServlet.loginUser: Redirecting to https://X.X.X.X:443/CSCOnm/servlet/com.cisco.nm.cmf.servlet.CsAuthServlet?cmd=loginSuccess&id=E2B64EA9935CEA2BAF8392AE77B7628E&page=CSCOnm/servlet/com.cisco.core.mice.main?command=initializeAndValidate&url=/cwportal/c/portal/login&context=/cwhp&port=...
RM isValidReq decodedAddr is :  10.107.16.82
RM isValidReq remoteAddr is :  10.107.16.82
on pdshow, I noticed that dcrserver failed.
I think that I will open an SR.
Many thanks,
Elisabeth
