09-02-2009 08:54 AM
Running archive sync jobs and showing multiple failures.The cause for the failure states: Unable to get results of job execution for device. Retry the job after increasing the job result wait time using the option:Resource Manager Essentials -> Admin -> Config Mgmt -> Archive Mgmt ->Fetch Settings
We have to restart services almost daily basis now to clear the problems. I'm guessing we are hitting a bug. We are planning to upgrade to LMS 3.2 and wondering if this will solve the problem, or introduce others.thanks in advance
09-02-2009 09:00 AM
Your subject and body are confusing. You say you're running LMS 3.2, but you'd also like to upgrade to 3.2. If you're actually running 3.1, then this is most likely CSCsv95235, and it is fixed in LMS 3.2.
09-02-2009 09:10 AM
fat fingers today. We are running 3.1 and are planning a 3.2 upgrade
Thank you!
09-02-2009 09:11 AM
Then you should be good to go once you upgrade to 3.2.
