LMS 3.2 Blank Screen after Authenicating
eamonconnolly
I have installed LMS 3.2, I double click the icon and I get asked to authenticate, which seems to work fine but the next page that it tries to load doesn't fails.  I get the standard "Internet Explorer can display the Webpage" page.
The url it is trying to load is as follows, https://ciscovms005/CSCOnm/servlet/com.cisco.nm.cmf.servlet.CsAuthServlet?cmd=loginSuccess&id=995AB43228F147B277BB512960950222&page=CSCOnm/servlet/com.cisco.core.mice.main?command=initializeAndValidate&url=/cwportal/c/portal/login&context=/cwhp&port=....
From what I can see this is the standard page but it is not loading for some reason.
I have seen a few posts with similar problems and have tried what they suggest but it has not sorted my problem.
any help would be gratefully received.
Eamon
Gaganjeet Chug
Level 4
Level 4
You seems to be hitting famous LMS 3.2 redirection bug :- CSCtb17186
You can view this bug at the below URL :-
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCtb17186
Kindly apply the workaround of the bug and then restart the daemon manager to fix this issue.
Workaround:
First, make sure the server is running a supported configuration as per
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html
If the problem persists, open regedit.exe, and create or modify the following
registry key DWORDs:-
( NOTE :- Please take the complete backup of registry before making the below changes to be on safe side )
HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet
Settings\Zones\0\1A10 : DWORD : 0
Settings\Zones\1\1A10 : DWORD : 0
Settings\Zones\2\1A10 : DWORD : 1
Settings\Zones\3\1A10 : DWORD : 1
Settings\Zones\4\1A10 : DWORD : 3
Then restart CiscoWorks Daemon Manager.
Gaganjeet
Gaganjeet Chug
Level 4
Level 4
Workaround:
Gaganjeet
Thanks gachugh,
This was exactly what the issue was, I checked the bug and went through the steps it suggests, checking the server prereq's, etc.  These were all fine, I made the suggested registry changes and it fixed my issues.
Excellent work
Thanks again
Glad to know it fixed the issue.
Gaganjeet
