LMS 3.2 Campuss Data Collection Does Not Start
uffankhan
          I Discovered devices correctly in CS>DCR . Initially there was no problem in running data collection in Campuss Manager. But now when i try to run data collection manually or by a scedule, it does not start. Although the notification appears that "notified server to run data collection" but nothing happens then.
Also, I applied " net stop crmdmgtd" and then "net start crmdmgtd" and no error was reported. After this, data collection was successfully run, but just for once. That means, every time if i have to run data collection manually or by a schedule, i have to stop and start crmdmgtd ???
Please advise what to do.
Pleae note:
LMS 3.2 is installed on Windows Server 2003 service pack 2.
It looks like you are on Campus Manager 5.2.  This should be fixed in 5.2.1.  Proceed to upgrade to this version and then see if Data Collection runs fine.  If you still have any problems, post the latest ani.log.
5 Replies 5
Joel Monge
Post the CSCOpx\log\ani.log.
Thanks for considering, i am uploading the required log file.
Ok, thanks for the advice. I will let you know the results.
Thanks Joe , the problem got resolved when i updated the CM from 5.2.0 to 5.2.1 .
Thanks !!
