07-26-2013 10:53 AM
I am interested to get UT for ip-phone, I have Avaya Call manager and Avaya Ip-phones, is that can be done? or the call manager should be CCM (cisco call manager) to get the detail information on UT? if that can be doen what's the first step should I do? thanks,
Solved! Go to Solution.
07-27-2013 12:31 AM
Unfortunately, Cisco doesn not supports third party phones and Call manager. Yes you need to have Cisco's IP Phones and CCM.
Third party IP Phones will be taken as normal end hosts.
-Thanks
07-27-2013 12:31 AM
-Thanks
07-27-2013 12:32 AM
Please see the supported devices list for LMS 3.2 here:
-Thanks
