ā04-21-2011 02:35 PM
Hello Dear's
We have installed CS 3.2 and RME on 1 server on C: Drive. Now the problem is C: Drive is full with MB of space behind, when i went through the Cisco Works folder i found location CSCOpx/files/rme/syslogpurgeddata files are occupying space in GB so i planning to delete these files,
My concern is if i m deleting these files is it will crashed my CS and RME.??????????? AND these files are just the sylogs which have been received by devices????? Correct me if i m wrong
ā04-22-2011 04:13 AM
Hi ,
Yes there should not be any problem if you clear that : ( CSCOpx/files/rme/syslogpurgeddata)
Please make sure you are not deleting the syslogdb files under (CSCOpx/database/rmeng)
Rest everything should be fine..
Thanks--
Afroj
If this post answers your question, please click the "Correct Answer" button"
ā05-31-2011 07:20 AM
Hello Afroj,
I dont want it to be deleted manually. They shld be deleted automatically according to the syslog purge job which is default to 7 days in RME..Please correct me if i m wrong???
Why is it so the syslog purge job not working in RME.
ā05-31-2011 07:39 AM
you HAVE TO delete these files manually - for details about the meaning of "syslog purge" jobs and "syslog backup" (which is the cause of the issue) see this thread:
https://supportforums.cisco.com/message/3209757#3209757
ā06-02-2011 03:29 PM
Thanks for ur reply,
RME is 4.2 and CS is 3.2.
ā06-02-2011 04:07 PM
you are correct, syslogfirst.db,syslogsecond.db and syslogthird.db are files you should never delete manually and you need to contact TAC to get the procedure and the necessary java file to reclaim the diskspace.
But like Afroj mentioned it is save to delete the files in NMSROOT/files/rme/syslogpurgeddata
syslog consumes a lot of disk space when a lot of messages are coming in.. Firewall logging send to the syslog server could be a reason as well as roaming messages from wireless APs - or it is just the "normal" behaviour - it depends on the network.
Reinitialization of RME will removes all data from RME - like device configuration, inventory all your RME jobs and all historical data. I definitely would prefer contacting TAC.
But if you have set syslog purge to 7 days from the beginning I assume the amount of your syslog messages is huge and if that is truth I doubt that you could reduce the size of syslogfirst.db, etc.
What is the size of these files?/files/rme/syslogpurgeddata?
[edit]
as far as I know DBSpaceReclaimer.class is included in LMS 3.2 - but currently I cannot verfy it. It will remove the three dataspaces (syslogfirst.db, etc.) and - if I remember well it - will also whipe out the current content of the RME syslog db
the header of this thread mention LMS 3.2 but in your last post you wrote CS 3.2 RME 4.2 - both are LMS 3.1 - verify your version under Common Services > Software Center > Software Update; an overview of all LMS applications and versions can be found here: Cisco Works - Appliccations and Versions -
ā06-03-2011 03:01 AM
Hello Mermel,
Thanks for ur precious reply,
It is a Mistake from my end,Cisco Security Manager 3.2 whcih includes RME 4.2 and Common Services 3.2.
