LMS 3.2 device updates failing?
Have upgraded from LMS 3.1 to 3.2 then applied all the software updates ok.
Now applying device updates - they are failing but can't see a clear reason. The Activity Log > Event Log doesn't really provide any clues. I'm guessing the relevant log file would be the psu.log ? [see attached]
Not sure if messages like
oid : 1.3.6.1.4.1.11.2.3.7.5.19 not found in E:\CISCOW~1\lib\classpath\com\cisco\nm\cwcs\mdf\mdfdata.xml
are part of the problem?
Thanks for any troubleshooting pointers
Michel Hegeraat
Level 7
Level 7
The SYSobjectID you mention is of an HP device so that is not likely to be your problem.
Got any problems with devices not being recognized?
Tail of psu.log looks normal to me.
Cheers,
Michel
Michel,  thanks for the reply.  I didn't notice the non-Cisco oids.
I have now dumped my entire DCR to csv and none of the non-Cisco sysObjectIDs in the psu.log warning messages are in the DCR export.
Mysterious...
