LMS 3.2 DFM Fault History purge Job
patrick.peuten_2
Beginner
Beginner
Hey experts,
the Online Help for LMS 3.2 say "Data for Fault History remains in the DFM database for 31 days".
How can I increase or reduce the amount of days the data will remain in the DFM Fault History Database?
Is it possible to have only 10 Days in Fault History or can I set it up to 60 Days?
Is there a specific config file which could be edited for my purposes?
I know the purge Job for Fault Hostory but it purges the data which is older than 31 days, I can´t adjust this job.
thx,
Patrick
Joe Clarke
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
No, this is immutable.  The only thing you can change is the TIME at which the purge happens.
Recognize Your Peers
