08-29-2011 03:55 AM
Hi all,
the customer has a problem with LMS 3.2. This software doesn't terminate ssh sessions created by LMS on ACE. All ssh sessions still exist on ACE, so no new ssh session can be created until the administrator manually clear these session on ACE. Thank you for your advice.
Roman
08-29-2011 06:04 AM
This could be device side bug as there is no such bug for LMS 3.2 , although some bug had been identified for the ssh connectivity issue which all are fixed in the LMS 3.2.1 which is service pack of LMS 3.2.
CSCth84178 Data retrieved from a device example device configurations is truncated when CiscoWorks Resource Manager Essentials archives large device configurations using SSH.
CSCtd52217 SSH2 connectivity fails. The reason for the failure being invalid signature error with cmdsvc.
CSCth47018 Device Credential Verification Job hangs when testing SSH.
CSCth81713 Device Credential Verification uses Secondary Credentials for SSH Enable test.
CSCte95623 Support for config archive using SSH2 in IOS-XR devices is not provided.
CSCtg43962 Configuration Management operations such as configuration fetch or netconfig deployment fail to complete. Trying to perform additional operations after this failure do not work. Only after ConfigMgmtServer is restarted do certain configuration management operations work again
Many Thanks,
Gaganjeet
08-29-2011 08:10 AM
Hi Gaganjeet,
thank you very much for your reply. But I think, that this problem is with LMS, because I used some manually created SSH sessions on ACE an these sessions was terminated correctly. I'm sending you the output from one ACE module:
ace1/Admin# sho ssh session-info
Session ID Remote Host Active Time
789 10.210.40.41:24389 280: 2:14
3946 10.210.40.41:37910 160:47:13
7394 10.210.40.41:46981 256:46:54
11129 10.210.40.41:11010 136:46:43
11651 10.210.40.41:11295 136:40:53
14651 10.210.40.41:20522 232:46:45
15143 10.210.40.41:20759 232:42:26
18317 10.210.40.41:32636 112:47: 5
19061 10.210.40.41:35109 112: 2:25
19152 10.210.40.41:35240 112: 0:20
21886 10.210.40.41:42629 208:47: 1
22383 10.210.40.41:42839 208:43:14
25713 10.210.40.41:7305 88:47: 4
28996 10.210.40.41:48379 400:47: 8
29105 10.210.40.41:16016 184:47:16
29579 10.210.40.41:16193 184:44:15
You can see that there are a lot of ssh sessions from LMS (10.210.40.41) with the long active time.:-(
Roman
12-05-2011 12:03 AM
We have same problem with ACE and RME.
Hvae you found any solution for this problem??
12-05-2011 08:21 AM
Hi Karoly,
The problem was with the Archive Poller. I increased the fetch interval from 180s to 240s ((RME-Admin-Config Management- Fetch Interval) and the problem was solved:-)
Roman
12-05-2011 11:17 PM
VERY THANKS!
12-05-2011 11:56 PM
Hi!
It is not solved my problem!
30058 10.42.10.227:49171 0:16:59
12-06-2011 12:20 AM
as I wrote before my problem was caused by Archive Poller. So my problem was solved by fetch interval.
You have to find the cause of this problem in LMS (maybe some software poller, ip sla...). I'm not the LMS expert, but I checked the scheduled time for different pollers and when I found the correct time - I troubleshoot the possible problem.
Roman
