LMS 3.2 evaluation: language error
Volker Janusch
Level 4
Level 4
The installation stops with error "... unsupported locale..". The system is "Win2003-Server R2" completely installed with English version an regional settings as recommended (Englisch (US)). CWLMS 2.6 was working fine. What can I do?
Manager DC-Networking, Automation & WLAN
Logicalis GmbH
That's the problem. Set the top key value to 00000409 (i.e. set the default user locale to US English). Then the install will work.
6 Replies 6
Joe Clarke
Post the output of the SYSTEMINFO DOS command. While the system may be localized for US English, it may not be a US English version of Windows. The latter is absolutely required for proper operation.
systeminfo.txt attached.
Logicalis GmbH
What is the value of the following two registry keys:
HKEY_USERS\.DEFAULT\Control Panel\International\Locale
HKEY_CURRENT_USER\Control Panel\International\Locale
HKEY_USERS\.DEFAULT\Control Panel\International\Locale = 00000407
HKEY_CURRENT_USER\Control Panel\International\Locale = 00000409
Logicalis GmbH
Yes it works. Thank You very much.
Logicalis GmbH
