LMS 3.2 on Solarios 10 - How to Decomm a device without removing it
josefribeiro
Beginner
Beginner
Hi All,
I have a situation where we are decommissioning several switches. After the devices are gone I'd still like to keep their information and archived config for documentation purposes but I'd like that RME and DFM would stop processing them.
Is there a way to do that?
Thanks in advance.
Jose Ribeiro
AFROJ AHMAD
Hi Jose ,
If you do not DELETE  the Device  from Cisco works then you would be able to get the configuration of the Device from cisco works even if the Device is no longer in your network.
(NMSROOT\files\rme\dcma\shadow)
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
And to make RME and DFM to stop processing you can suspend the device in RME, in DFM you have to stop the auto allocation, then you can delete a device just in DFM
Cheers,
Michel
Recognize Your Peers
