Showing results forĀ
Search instead forĀ
Did you mean:Ā
lms 3.2 snmp write community
Hi, I am looking to pull configurations, make changes  and deploy ioses.
I did a device discovery and found all of my devices.
I am looking to do an SNMP walk and SNMP set but the object ID is not populated and I wouldnt think it be neccessary to populate sys id objects.
Would you know what I can do to fix this?
Also to minimize questions to you guys is there any link to a pdf that help guide how to setup and perform various tasks for lms 3.2.
fyi this lms server is using authenication with acs.
In addition the last request I wanted to know where I can set the wr community that will associate the cw server with the common wr community string.
