05-20-2011 03:27 AM
We have a problem with our LMS 3.2 campus manager - Network View - VTP Views. We used to customize the device connectivity layout but everything collapsed to default appearance. We used to SAVE the layout each time but this happened twice.
Please suggest what could be the problem.
Guru
Solved! Go to Solution.
05-21-2011 01:34 PM
There is a known bug where using a topology map background image causes the map layouts not to be saved properly. The workaround is not to use a background image. Additionally, the XML files under NMSROOT/campus/etc/users/USERNAME may become corrupted (from a partial save). Restoring them from a good backup will restore proper map layout. Finally, if the ANI database is reinitialized, the map layouts will change as the device IDs change.
05-21-2011 01:34 PM
05-22-2011 11:37 PM
Hi Joseph,
Thankyou for the response. I would appreciate if you could share some work around or solution to this issue.
Guru
05-22-2011 11:41 PM
I've also provided you workarounds based on common known issues. If the problem is the database was reinitialized, there is no workaround. The maps must be rebuilt manually.
