05-22-2014 01:20 AM
Hi all,
knowing that LMS 3.21 is a really outdated version of LMS I actually struggle with CM 5.2.2-UT Application.
Environment:
- LMS 3.21 (Mdf. 1.89, CMDeviceUpdates.CM522.v3.0)
- Solaris 10
- Cisco Catalyst 4510R+E (IOS-XE Version 03.03.00.SG)
Linecards in Slot 9/10: WS-X4648-RJ45-E
Problem:
UT Discovery only discovers Endhosts on Switchports until Modul-Slot 8. Endhosts connected to port on Slot 9/10
won't be collected (in /opt/CSCOpx/campus/etc/cwsi/portsData.xml file no entries will be found on ports highter the slot 8).
But Endhosts can be seen with #show mac addr dyn on switch and with performing a snmpquery on dot1dTpFdb-Table.
Question:
Anybody out there knowing whether there is a limitation within LMS 3.21 not to discover switchports geater than module 8?
Any suggestions for further troubleshooting; I parsed thru several log files (ut.log, ani.log, ...)
For certain reasons we have to stay on this "old" version of LMS until we can upgrade to LMS 4.x or PI 2.x.
Thanks for any feedback
Lothar
Solved! Go to Solution.
05-22-2014 02:26 AM
This is a known issue in LMS where Module 9/10 aren't displayed correctly for the End Hosts with them.
The issue is caused by bug CSCue87491. You can try to upgrade to IOS XE 3.5.0E 15.2(01)E, where the issue isn't seen.
Downloading url of IOS XE 3.5.0E 15.2(01)E for 4510R/4500 SUP7-E :
http://software.cisco.com/download/release.html?mdfid=283289791&flowid=19223&softwareid=282046477&release=3.5.0E&relind=AVAILABLE&rellifecycle=ED&reltype=latest
-Thanks
Vinod
**Encourage Contributors. Rate them.**
05-22-2014 02:26 AM
-Thanks
Vinod
05-22-2014 04:47 AM
Hi Vinod,
thank you for this quick reply regarding my question.
With this problem I never thought that the Switch-Image is the problem.
We now will test your recommended Image in our LAB and the rollout in production.
I'll keep you updated.
Thanks for helping
05-26-2014 05:47 AM
After testing in the lab, we could sucessfully poll correct
endhost-information (mac,ip,vlan,port) from updated Cat4510R.
So the recommended image solves the problem.
Thanks for helping
05-29-2014 10:59 AM
Glad to know it helped. Thanks for the update.
-Thanks
Vinod
