2491
Highlighted
LMS 4.0.1 - Device update problem for CiscoView
I would like to update all CiscoView packages for my customer.
When I do :
Admin> System> Software Center> Device Update
I have a list of several updates to do :
Showing 1-15 of 15 records
Package Name Type Product Name Installed Version Available Version Readme Posted Date size
1.ASR1000DevicePackageCiscoView3.04.0ASR1000.cv50.v4-0.readme NANA
2.Cat3560DevicePackageCiscoView9.011.0Cat3560.cv50.v11-0.readme NANA
3.Cat3750DevicePackageCiscoView12.013.0Cat3750.cv50.v13-0.readme NANA
4.Cat6000IOSDevicePackageCiscoView31.031.2Cat6000IOS.cv50.v31-2.readme NANA
5.CVGenericPackageDevicePackageCiscoView1.41.5CVGenericPackage.cv50.v1-5.readme NANA
6.Cisco3400MEDevicePackageCiscoView4.05.0Cisco3400ME.cv50.v5-0.readme NANA
7.MetroEthernetDevicePackageCiscoView 2.0MetroEthernet.cv50.v2-0.readme NANA
8.Nexus5000DevicePackageCiscoView 1.0Nexus5000.cv50.v1-0.readme NANA
9.Nexus7000DevicePackageCiscoView2.03.0Nexus7000.cv50.v3-0.readme NANA
10.Rtr3900DevicePackageCiscoView4.05.0Rtr3900.cv50.v5-0.readme NANA
11.Rtr1900DevicePackageCiscoView2.03.0Rtr1900.cv50.v3-0.readme NANA
12.Rtr1800DevicePackageCiscoView9.010.0Rtr1800.cv50.v10-0.readme NANA
13.NGMARShareDevicePackageCiscoView1.151.17NGMARShare.cv50.v1-17.readme NANA
14.Rtr800DevicePackageCiscoView16.018.0Rtr800.cv50.v18-0.readme NANA
15.SwitchAddletsDevicePackageCiscoView1.281.31 NANA
But when I try to do these update, it always fails and I can see in the Event logs, this message :
Number of Packages Selected for Install : 1
For Product(s) : CiscoView
Install Invoked by user : admin
The Package(s) Selected for Install :
CVGenericPackage
WARNING :  CVGenericPackage(1.5):Consistency check failed for base package SwitchAddletsWhat can I do to update my CiscoWorks please ?
No package(s) to install for : CiscoView
Thank you.
Stephane.
7 REPLIES 7
Highlighted
And for each individual device package I'm trying to update, I receive this error message :
Error
The installation of device package(s) failed.
Check Software Center > Activity Log > Event Log for details.
And the Event log show me this (for example, for the Cat3560 package) :
Cat3560
But when I do Device Update again (even if I Stop and Restart the Deamon Manager), I still see the same device packages list.
This problem is very annoying.
Do you want me to upload any other log ?
Highlighted
Here is the psu.log file.
Highlighted
If I try to do it in CLI, here is the same error message I receive :
Checking Dependencies...
WARNING: Cat6000IOS(31.2):Consistency check failed for base package SwitchAddlets
There are no Packages to be installed
Highlighted
Nobody have an idea ?
Highlighted
Have you tried the SwitchAddlets update by itself? I used to see this some with older versions that base dependency packages (such as SwitchAddlets) needed to be installed first. Only after it is successfully installed will other device level packages install properly. (Although I haven't run into this issue myself with LMS 4.x).
Highlighted
I tried to install SwitchAddlets package alone, but nothing happened.
I still have this error message :
When I look into Event Log, I can see that the package has been correctly installed, but it is not !
When I do it again (Device Update), I still have SwitchAddlets in the list, very strange.
Look @ the joined screenshots.
Highlighted
Your last screenshot seem to indicate a file / directory ownership problem. All users (or at least "casuer" - the CiscoWorks built-in application user account) should have RWX rights of the psu_download directories and files.
Content for Community-Ad
