05-31-2011 08:10 AM
We have just installed LMS 4.0.1 and started to discover parts of the network. After the discovery process finished successfully - 100+ new devices were added to DCR message - I was able to see the devices by clicking on their number but when I go to Inventory-Add/Import/Manage Devices I cannot see any device in the Group that I created.
If I restart the CiscoWorks Daemon Manager process the newly discovered devices are added to the custom Group.
This seems like a bug as I had a LMS 4.0 evaluation installation a few months ago and device discovery was working fine meaning the devices were added immediately to the Inventory.
Any assistance is highly appreciated.
07-22-2011 06:39 AM
Hi Adrian,
I have the same problem , were you able to resolve the problem ?
gr
wim
07-25-2011 12:24 AM
Hi Wim,
No, the problem is not solved, from time to time I have to restart the virtual machine where LMS is installed in order to have the DCR updated with the latest devices discovered.
Are you using also a virtual machine for your LMS installation ?
Adrian
07-25-2011 01:31 AM
We are using a physical machine but even with a reboot I don't see the devices.
gr
wim
07-25-2011 09:18 AM
hi,
i had faced this issue. Just check casuser has the permission to your machine. Also is the machines in AD/ Standalone. I faced because of AD permission which was blocking casuser in local group permission.
