Hi All,
I 'm facing a issue with the discovery module, when i create a job for discovery either immediate or scheduled. The job triggers and status would be running.But i'm not able to see the progress of the discovery status(it displayed ""No recent information found) in the inventory>discovery>start/launch summary. No information is available on this page.
Attaching the CSDiscovery and ngdiscovery log files. Any help would appreciated.
Channa
Hi Guys...Any help ???
Have you defined your discovery protocols?
What is your seed device? LMS or did you pick a device?
Try using
"Use DCR as Seed List" and start with the core
Hi duong,
I'm using the ping sweep. not using the "Use DCR as Seed List" as there were more than 5000 devices.
Earliar LMS pick the devices. once the discovery was running for a long time . to stop the same we have restarted
the CSDiscovry process. After this we are facing the issue.
Channa
