05-13-2011 05:51 AM
I have just made a fresh install of LMS 4.0. I installed the 4.0.1 version too. It is done on a Windows 2008 STD running a WM environment.
I have only one problem : I cannot get the inventory collection for a 6500 VSS chassis. It is discovered, I got the archive configuration, it is visible on the data topology and on CiscoView but when I try to collect it for the inventory I got the following message :
R2-C6509-01 | Device Collection Failed. |
Someone has an idea?
Thanks by advance,
Abel JULIAN,
Nextiraone France.
Solved! Go to Solution.
05-13-2011 07:13 AM
Login to LMS, then point your browser to
http://SERVERIP:1741/rme/devices.do
select your device and click "Edit Device Attributes", then click "Inlide Edit" and adjust the SNMP timeout settings for this device; in a first step change it to 10 (default is 2); Save the settings by clicking "Modify" and on the next screen "Apply".
Retry Inventory Collection and see if it will be successful now.
05-13-2011 07:13 AM
05-13-2011 07:29 AM
Thanks you very much ! I was looking for this parameter (I had the same issue in LMS 3.2) but I am new in LMS 4.0.
Have a nice day
05-13-2011 03:59 PM
the reason why you could not find it is very simple - the web page is there, but they just forgot to integrate the link to the site in LMS 4.0 and LMS 4.0.1 - but the link is planned to be integrated in LMS 4.1- until then there is this workaround: just go the page directly...
