Highlighted
Beginner
LMS 4.0.1 - Nexus
Hello all,
I searched on the internet wothout success about this theme.
I just added Nexus 7k and 5k to the CW LMS 4.0.1. SNMP OK, SSH ok. I just see the IP, OS Type, Version, but the device is UNKNOWN. Are my NX-OS versions good?
The NX-OS versions are:
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.0(3)N2(2a)
  system:    version 5.0(3)N2(2a)
  power-seq: Module 1: version v4.0
  uC:        version v1.0.0.2
  SFP uC:    Module 1: v1.0.0.0
  BIOS compile time:       02/03/2011
  kickstart image file is: bootflash:/n5000-uk9-kickstart.5.0.3.N2.2a.bin
  kickstart compile time:  10/15/2011 9:00:00 [10/15/2011 18:44:53]
  system image file is:    bootflash:/n5000-uk9.5.0.3.N2.2a.bin
  system compile time:     10/15/2011 9:00:00 [10/15/2011 20:35:57]
Hardware
  cisco Nexus5596 Chassis ("O2 48X10GE/Modular Supervisor")
  Intel(R) Xeon(R) CPU         with 8299528 kB of memory.
  Processor Board ID FOC15434ZU5
  Device name: GYPRAC02G10
  bootflash:    2007040 kB
Kernel uptime is 25 day(s), 9 hour(s), 41 minute(s), 11 second(s)
Last reset at 1410 usecs after  Thu Dec 29 04:49:37 2011
  Reason: Reset Requested by CLI command reload
  System version: 5.0(3)N2(2a)
Software
  BIOS:      version 3.22.0
  kickstart: version 5.2(1)
  system:    version 5.2(1)
  BIOS compile time:       02/20/10
  kickstart image file is: bootflash:///n7000-s1-kickstart.5.2.1.bin
  kickstart compile time:  12/25/2020 12:00:00 [07/29/2011 13:34:35]
  system image file is:    bootflash:///n7000-s1-dk9.5.2.1.bin
  system compile time:     6/7/2011 13:00:00 [07/29/2011 15:29:25]
Hardware
  cisco Nexus7000 C7009 (9 Slot) Chassis ("Supervisor module-1X")
  Intel(R) Xeon(R) CPU         with 8260944 kB of memory.
  Processor Board ID JAF1544ARCN
  Device name: GYLNDS01G09--VD1
  bootflash:    2048256 kB
  slot0:              0 kB (expansion flash)
Kernel uptime is 25 day(s), 11 hour(s), 1 minute(s), 31 second(s)
Last reset at 566212 usecs after  Thu Dec 29 21:30:15 2011
  System version: 5.2(1)
  Service:
Thank you for your help!
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Guru
Your devices with the NX-OS versions you indicate should be OK per the LMS 4.0.1 Supported Devices Table.
Have you updated your LMS with the latest device packages? See the procedure here.
2 REPLIES 2
Highlighted
Hall of Fame Guru
Highlighted
Hello Marvin,
thanks! I was an issue with a bug (CSCto46927), after I installed the patch I was able to update the device packages. Thanks once again!
Content for Community-Ad
