LMS 4.0.1/swim:is it possible to upgrade to deferred ios?
ebezombes
Customer has an deferred ios install on his switch, He would like upgrade others switch with this defered ios.
Is it possible?
deferred ios: c3750-ipbasek9-mz.122-25.SEE4.bin
Thanks, Elisabeth
Nael Mohammad
Level 5
Level 5
As long as you have the image in the repository, you should be able to select it.  Go to Configuration --> Tools --> Software Image Management --> Software Repository --> Click Add --> Select "Device" and next and choose the 3750 that contains the deferred image to download to LMS.  Afterwards create another job to distribute to other devices.
