LMS 4.0.1 Topology services not running on Win7
ayojosh2k
Hello
Please i need help!!!
I installed LMS 4.0.1 and every module works from the local server. Http login from a remote system, topology services does not start, complains about java version. I followed the link to install the java version, it then complains about some Ansiserver stuff.
Can this be fixed.
the client os is win7 64 bits, eplorer version is 7.
Michel Hegeraat
Level 7
Level 7
You need to be able to resolve the hostname of the ciscoworks server.
On you pc if open a dosbox and type
ping
Can it resolve this name to an IP addres?
Cheers,
Michel
Michel Hegeraat
Level 7
Level 7
ping
Cheers,
Michel
