LMS 4.0 - a fault annotation
ROMAN TOMASEK
the customer uses LMS 4.0. He annotated one fault and he cleared this fault. So this fault was cleared and it wasn't seen in the fault monitor. For now the fault is again active and the annotation for this fault is shown. So my question is: Does DFM have some annotation database where all anotation of faults are saved? When the same faults re-occur and the annotation was made for this fault in history - this fault will be displayed with this annotation??
Thank you.
Best Regards
Roman
Joe Clarke
The annotations are saved to a specific event.  If the event re-occurs, that event will have a new ID, so the annotation will not be there.  Annotations are saved in the dfmEpm database.
Joe Clarke
thank you very much!! Roman
