Lms 4.0 and stacked 3750 v2
steve switzer
Lms 3.2 does not support stacked 3750 V2.
You cannot see it on topology map.
Will you be able to see it using LMS 4.
Otherwise when will it be visible
Steve
Joe Clarke
Both LMS 3.2 and 4.0 do support 3750V2 stacks.  They should be visible as Cisco switches on the topology map.  When it comes to stack switches, they all have the same sysObjectID, so they should just work with Campus and RME.  With CiscoView, you will need the latest Cat3750 package to view the chassis.
So do i have to download some new 3750 files .
Sorry to sound dense but where do i do this from.
You do not need to download anything for the topology and inventory and configuration features of LMS, however, for CiscoView, go to Admin > System > Software Center > Device Update, check the box next to CiscoView and download and install all available packages.  It's not a bad idea to do that for Common Services, Network Topology Layer 2 Services and User Tracking, Fault Management, and Inventory Config And Image Management, too just to stay up-to-date.  However, with 3750s, the sysObjectID is typically the same for all models so unless you need chassis-specific management, features of LMS should just work with them.
