Darko Gmajner
Beginner
LMS 4.0 ASA-SSM-10 Sync archive
Hello.
During Sync archive for ASA-SSM-10 which is installed in ASA 5505 device I received the error:
*** Device Details for Cisco ASA IPS ***
Protocol ==> Unknown / Not Applicable
Selected Protocols with order ==> Telnet,SSH
Execution Result:
RUNNING
CM0151 PRIMARY RUNNING Config fetch failed for Cisco ASA IPS Cause: TELNET: Failed to establish TELNET connection to 172.26.22.32 - Cause: Authentication failed on device 3 times.
SSH: Failed to establish SSH connection to 172.26.22.32 - Cause: Authentication failed on device 3 times.
Action: Check if protocol is supported by device and required device package is installed. Check device credentials. Increase timeout value, if required.
The connection to this device (ASA-SSM-10) is possible with SSH protocol with Putty and with SecureCRT. What has to be change in the LMS to sucess with Sync archive and later with changing the archive with the LMS 4.0. Thank you.
1 REPLY 1
Nael Mohammad
Contributor
Post the show ver of the device and we can verify if its supported or not and the OID as well.
