LMS 4.0 Best practice
Hello there
I'm running LMS 3.2 at the moment.
Going to LMS 4.0 next on a new standalone server, and I'm asking for a best practice to configure the new LMS.
Anyone know?
Thanks in advance!
AFROJ AHMAD
Hi ,
below are the thing that you need to take care of during the Installation.
1.      1.  You should be logged in as a LOCAL ADMINISTRATOR account.
2.       2. Only the Essential windows program and services should be checked on the Server for DEP. See the attached Image:
3.    3. Have the TEMP and TMP variables set with a short length. It is required because the normal default variables sometimes exceeds 32bit
ch  Character length and have the installed hampered which uses command prompt at the background to invoke various tasks (they should be made sort such as C:\WINDOWS\TEMP and C:\WINDOWS\TMP): see the attached Images
4.      4.  Please have almost all the 3rd party software’s services disabled till the time updates/install is in progress, specially Avti-Virus programs.
T    Thanks--
      Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Refer the LMS 4.0 Deployment Guide for details on installing the product.
Rob
Recognize Your Peers
