Marvin Rhoads
VIP Community Legend
LMS 4.0 Hardware Report
I am looking for but not finding a simple report. I would like to query my LMS 4.0 data for a report containing a few basic fields:
Device type, device name, IP address, and location
I can't imagine that's an uncommon need yet I don't see it in any of the myriad options. Any suggestions?
1 REPLY 1
Marvin Rhoads
I figured it out - needed to create a custom report (Reports, Report Designer, Syslog and Inventory, Custom Report Template). Create a new template from there, name and save it.
Once you've done that, the new report will appear on the Reports page. You need to just click on "Reports" in the menu bar. The drop down menus from the mouse-over will not show it - but if you click on "Reports" the resultant page will show the new report under the "Inventory" tree.
Hope this helps someone else with this task.
