05-22-2011 07:31 PM
I have been having problems getting devices into DFM once I enable fault management.
I am now having issues with the basic LMS / RME
I am getting the following issue:
"No Device exists in LMS or Inventory is not collected for devices."
I experienced this before and resolved by reapplying the licence.
Where to next ? any suggestions?
The issue has gone from - all devices discovered and added to LMS and DCR ok
Turned on Layer 2 Topology and Faults and then no devices appearing in DFM.
after restarting the Daemon manger I have no devices in LMS. total device approx 1900 - standalone setup.
License Info
License Type | Permanent[LMS] |
Device Count | 5000 |
05-23-2011 03:31 PM
Ok issues resolved by removing and re-applying the licence file after a daemon restart.
This appears to be a common issue and fix?
Dave
07-09-2011 06:46 AM
I'm seeing this from time to time on LMS 4.0, the 4.01 and on the 4.1 beta.
I've seen it appear after running a device package update.
And to resolve ussually a stop and start of the deamon manager is sufficient.
Did you even get to the bottom of this? Any permanent sollution?
Cheers,
Michel
09-07-2011 05:06 AM
I've the same problem on LMS 4.0.1, but the deamon restart doesn't solve this issue. If you have another workaround, please post it.
Thanks.
09-20-2011 11:33 AM
Happened to me a couple of times I had reboot the entire server to get this resolved. Has anyone tried contacting TAC?
11-14-2011 03:35 AM
I had the same problem, but i reinstall the license file , restarted the deamon manager and the problem was solved.
Thanks Dave!
