Highlighted
LMS 4.0 - NVRAM state
I want to poll and verify the state of NVRAM in C6509 devices.
Because the issue of "Configuration lost" after device reloads were observed.
I thought of proactively monitoring the state of device NVRAM.
Which MIB and OID will help me in monitoring the state of NVRAM?
Rajmohan R
Everyone's tags (1)
4 REPLIES 4
Highlighted
Hi Raj,
1.3.6.1.4.1.9.5.1.1.67
sysStatus OBJECT-TYPE
SYNTAX INTEGER {
other(1), -- none of the following
ok(2), -- status ok
minorFault(3), -- minor problem
majorFault(4) -- major problem }
MAX-ACCESS read-only
STATUS current
DESCRIPTION "The operational status of the system."
::= { systemGrp 67 }
I just test this OID , it is working..
I hope this will help
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Highlighted
Hi Afroj,
When checked with MIB browser on C6509, i got "ok" as response.
Is this response indicates the overall system status or only the status of  NVRAM.
Rajmohan R
Highlighted
Hi Raj,
This is The operational status of the system. I mean "over all System status.
afroj
Thanks Ahmad for the clarification.
However, is it possible to poll and check only the state of NVARM in C6509?
Rajmohan R
Content for Community-Ad
July's Community Spotlight Awards
