04-24-2012 10:45 PM
Hi all,
I have two LMS servers which are used to manage the same network. The requirement is to have two independent LMS platforms. But i want to synchronies the LMS configuration database/settings between these two servers. I.e. if are changing the inventory in one of the LMS same information should be available in second one. The changes applied to particular LMS must be synchronized to the second server like
1) User roles
2) Inventory changes
3) Jobs
4) Reports
5) collectors etc
How we can configure this ?
04-25-2012 09:39 AM
I think backup - restore is the easiest solution
Cheers,
Michel
04-25-2012 09:27 PM
Any script available to sync between two database tables ?
04-25-2012 11:38 PM
I'm not aware of such a script, but there is an High Availability solution available from cisco.
Since the underlying products were not designed to run in a High Availability way it uses 'other' ways to sync the disks of the 2 servers.
Anyway the backup is a good start of all the data you need to sync in terms of databases and files.
Cheers,
Michel
