05-28-2011 11:58 AM
i've added a Cisco ACS as device to my LMS. I configured the ACS to send syslog messages to the LMS server and i can see them in the syslog file. Unfortunatly it seemes the messages are not processed and i can not see the in the syslog report.
any ideas?
thanks & regards
alex
05-28-2011 08:26 PM
No, the ACS syslog messages are not supported by LMS. The ACS is not a fully supported device by LMS Inventory and Config.
05-31-2011 03:13 AM
So it means i have to provide another syslog server for my ACS logs?
regards
alex
05-31-2011 11:23 AM
You can use LMS as your syslog server, but you will have to mine the messages from the syslog.log directly. They will not be added to the LMS database.
