xcz504d1114
Enthusiast
LMS 4.0 Unreachable Interface IP's
I'm trying to cleanup some errors in LMS 4.0, the interfaces are
up, but the IP's of the interfaces are not reachable.
How can I stop LMS from polling those specific IP addresses with ICMP, but still alert me if they are up / down?
The interfaces are used for DMVPN tunnels, and their IP's are not redistributed throughout the entire network.
Craig
1 ACCEPTED SOLUTION
Michel Hegeraat
Rising star
If you open the device in DFM's detailed view you can select what ports, interfaces and IP addresses should be managed.
You can try to disable the management on the IP address and see if the interface is in a managed state, possebly set it to managed yourself.
Cheers,
Michel
10 REPLIES 10
Michel Hegeraat
Rising star
Cheers,
Michel
Thanks for the reply Michael, that definitely gets me in the right direction! Any ideas on how to do this for 1100 devices? The first two octets are the same for all 1100 devices, maybe a manual modification directly to the datastore?
The LMS GUI wont let you do this for mutiple devices
Doing this will involve some asl scripting...
You need to speak to someone who knows EMC SMARTS asl language.
Its not something I have time for now unless you are a customer :-)
Sorry.
Michel
I totally understand! Thanks again for the help, I'll get it figured
out!
I got the SMARTS utils working pretty quick, thanks again for the direction!
Thats cool.
I just wanted to point you to the file: CSCOpx\objects\smarts\rules\discovery\custom\custom-end-post.asl that is used to make changes to the management settings, but I guess you already found your way  :-)
If you find a doc clearly describing the objects you can test on and set, please post the link here.
Cheers,
Michel
I actually found some default scripts and bat files in the CSCOpx/object/smarts/utils/ folder.
There are 4 get bat files that execute ASL scripts, then dump the output into CSCOpx/objects/smarts/local/logs/ folder.
I ran getStateIP, which created a ExpIP.txt file, then I used notepad ++ and did a find / replace using regular expressions to match on the first two octets and replace the word "MANAGED" with "UNMANAGED". Then I used the setStateIP bat file to re-imiport the txt. I also did the same thing for my dialer interfaces using the getStateIntPort bat file, which executes 2 scripts, one for switch ports and another for router interfaces.
Here is an example output and modification (hopefully helpful to someone):
expIP.txt file:
IP:IP-10.101.1.1 MANAGED_STATE:MANAGED
IP:IP-10.102.1.2 MANAGED_STATE:MANAGED
IP:IP-10.10.1.1 MANAGED_STATE:MANAGED
regular expression for find and replace in notepad ++:
search:
^(IP:IP-10\.10[1-2].*:).*
replace:
\1UNMANAGED
result:
IP:IP-10.101.1.1 MANAGED_STATE:UNMANAGED
IP:IP-10.102.1.2 MANAGED_STATE:UNMANAGED
I did find this doc on Cisco that might be helpful for any real scripting someone might want to do.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_connectivity_monitor/1.1/user/guide/PerlReferenceGuide_Cisco.pdf
Thats cool Craig,
But you still got to check if now your "interface" is still managed while the unreachable IP is unmanaged.
Also there is a rediscovery schedule that often is set to make DFM able to pickup changes on the devices, but it may revert the changes you made.
You can suspend the schedule is you know the network is not changing.
Cheers,
Michel
After I modified the database with those standard scripts, I verified it was just the IP address and not the interface that was unmanaged. Looking at the GUI it marked the IP's as "false" and did not delete them, so I wouldn't expect the rediscovery to put them back into monitoring, but I will know for sure tomorrow, as the rediscovery / collection kicks off tonight. If it does re-monitor those IP's, I will try to use the setting "exclusively_unmanaged", I'm not sure what the difference is at the moment, but I did see one IP in the database that was already set to that.
I appreciate the help Michel!
Craig
This may or may not be relevant, but I remembered this thread as I ran across the following document:
LMS 4.1 Database Schema
http://www.cisco.com/en/US/customer/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/database_schema/dbviews_41.html
Craig
Content for Community-Ad
