sreelalggbm
Beginner
LMS 4.1 config Archive Issue
Hai,
We have LMS 4.1 with more than 150 devices.
Config Archive is failed for around 20 device.
11- Cisco VG248 ( Cisco analogue gateway)
7  - Cisco call manager
2 - Wireless Lan controller
For this device-  discovery, Inventory Collection ,Fault Discovery,  Topology Data Collection ,etc are successfull.
Can you please advice me what could be the reason for this issue
Sreelal
3 REPLIES 3
jul.delima
Beginner
Hi Streela,
Are you sure that these devices are supported by the LMS ?
I also have a WLC and I know that the software version of the WLC is not supported on my LMS.
I know that it is already a late answer... But I do no like to see a question no answered...
BR
Julian
Hai,
Thanks for the reply
I am facing the same issue  with some switches also
Are you sure that the LMS support the config collection on these devices ?
Check on this link :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/device_support/table/lms41sdt.html
If yes, it means that you have a problem for the file transfer... I would suggest to debug like this :
1) Check the credentials (Inventory->Job Browser->Device Credential Verification Jobs, then create a new one)
2) Is it possible to do a tftp from the device to the LMS ? (If the config is done by tftp)
     Create a tmp file on /tftpboot on LMS
     Copy the startup or running file from the device to the LMS with the name of your tmp file (it is not allowed to create a file on the LMS with TFTP)
3) Do a sniffing of the traffic between the LMS and the device in order to see what happen
     Go on http://:1741/cwhp/PacketCapture.do
BR
Content for Community-Ad
