LMS 4.1 device discovery will not start when launched manually
savic.marija
Beginner
Beginner
I have problem in recently installed LMS 4.1
Device discovery will not start when launched manually. When i hit the button, it doesn't even give a popup window saying that the discovery is started and that email will be sent... If I schedule it is launched, runs and finishes correctly.
All proceses are started and it seems that application is working ok.
LMS is installed on Win 2008 R2.
Does anyone happen to know about this problem?
Thanks!
Regards,Marija
1 REPLY 1
cruzersdyna
Beginner
Beginner
If you go into the processes and click on CSDiscovery then start, it will run the discovery.  That's just a work around for now.
