03-11-2013 11:54 AM
Hello, i used the software center to download latest device packages, all downloaded to PSU_Downloads folder , i want to know how to install them with GUI if possible , as i tried to use CLI but it seems that i'm using bad syntax.
Best Regards.
Solved! Go to Solution.
03-11-2013 04:37 PM
The cli syntax can be a bit tricky. If you have already downloaded the updates, you can perform the updates using the downloaded copies as your source. Please see step 2 of the procedure listed here, specifically:
To check for updates from a server, select the Enter Server Path radio button and enter the path or browse to the location using the Browse tab.
03-11-2013 04:37 PM
03-11-2013 11:53 PM
Many Thanks Marvin
