xcz504d1114
Enthusiast
LMS 4.1 Patch Distribution Failure
I didn't have this problem in 4.0, and I've tried to upgrade 2 different model routers (891 and 2811) with the same error, anyone know what this means? Google was no help.
SWIM0151: The device is not running IOS Modular image in Install mode. Hence patch images cannot be distributed.
Craig
1 ACCEPTED SOLUTION
Joe Clarke
Hall of Fame Cisco Employee
It sounds like you're trying to use the Pathc Distribution workflow for non-modular devices.  Do not select Patch Distribution.  Instead, select Software Distribution, and then follow the specific flow you want from there.
2 REPLIES 2
Joe Clarke
Joseph, as always, thank you very much!
Craig
Content for Community-Ad
