lassebjoern
Beginner
LMS 4.1 sync archive 'partially successful' on some devices
I'm having trouble syncing the config archive for some of my nodes.
I get the error 'partially successful' (see attatched PNG).
I've looked in the dcmaservice.log (also attatched), and I can see the extended error message:
[ Wed Jan 11  09:49:30 CET 2012 ],ERROR,[Thread-2137],com.cisco.nm.rmeng.dcma.configmanager.DeviceArchiveManager,getLatestConfigFileVersion,168,CM0021: Version does not exist in archive $1 Cause: Version may have been deleted
[ Wed Jan 11  09:49:30 CET 2012 ],INFO ,[Thread-2137],com.cisco.nm.rmeng.dcma.configmanager.DeviceArchiveManager,getSysObjectID,425,SYS OID = .1.3.6.1.4.1.9.1.987
[ Wed Jan 11  09:49:30 CET 2012 ],ERROR,[Thread-2137],com.cisco.nm.rmeng.dcma.configmanager.DeviceArchiveManager,addNewConfigFileVersion,1009,CM0012: Unable to create new version on archive $1 Action: Check if disk space is available and directory has required permissions
[ Wed Jan 11  09:49:30 CET 2012 ],ERROR,[Thread-2137],com.cisco.nm.rmeng.dcma.configmanager.DeviceArchiveManager,archiveNewVersionIfNeeded,1274,CM0002: Could not archive config Cause: Device may not be reachable, may be in suspended state or credentials may be incorrect. Action: Verify that device is managed, credentials are correct and file system has correct permissions. Increase timeout value, if required.CM0012: Unable to create new version on archive $1 Action: Check if disk space is available and directory has required permissions
I would like to check the file structure / permissions, but since I don't know what '$1' refers to, I'm stuck.
Anyone got at cluse on where to look, or other things to look for?
Thanks a lot!
Lasse
2 REPLIES 2
Svetlana Radzevich
Hi Lasse,
in GUI, go to Admin -> Collection Settings -> Config - under Config settings you will see the path where configuration is stored. By default it is $NMSROOT\CSCOpx\files\rme\dcma\devfiles.
You should double check that all folders have casuser:casusers permission.
Hope it hepls.
As a workaround you could delete and re-add problematic devices to LMS. Please be aware that you will lost all historical information about the device in this case.
Svetlana
Hi Svetlana,
Thanks for your reply.
I should add that this problem came after importing a LMS-backup to my installation.
Here's what I tried after reading your post:
1. Changed $NMSROOT\CSCOpx\files\rme\dcma\* ownership to casuser (was administrator), and checked that group casusers had admin access (it already had). No change in behaviour.
2. Removed one of the faulty devices, and re-added it. Still the same error.
it feels like there's some old stuff lingering from the backup that's conflicting with some newer stuff, archive-wise...
Some devices can sync to their archive, and and some can't.
Any other clues I should know about?
Thanks in advance!
Lasse
Content for Community-Ad
