07-18-2012 05:40 AM
Hi all,
we had a new installation on our solaris 10 server of LMS 4.21 (first LMS 4.2 then update to LMS 4.21).
Trying to update Mdf with
/opt/CSCOpx/bin/PSUCli.sh -p cmf ....
I got result stating that cmf is unknown.
With performing PSUCli.sh -h cmf is obviously not known to PSUCli.sh (please see following 'strange' output)
</opt/CSCOpx/bin># PSUCli.sh -h
Package Support Updater Usage : [ psu refers to this CLI executable ]
> psu -help
> psu -p <product1, product2...> -query [-src dir ] {-all |
> PackageNames} psu -p <product1,product2...> -install -src dir {-all|
> PackageNames} [-noprompt] psu -p <product1, product2...> -uninstall
> {-all | PackageNames } [-noprompt] psu -p <product1,product2...>
> -download -dst dir{-all | PackageNames} psu -p <product1,product2...>
> -software -dst dir{-all | PackageNames} psu -p <product1,product2...>
> -pointpatch -dst dir {-all | DefectID} psu -p <product1,product2...>
> -pkgDependents [-src dir] {-all| PackageNames} psu -p
> <product1,product2...> -pkgVersion [-src dir] {-all| PackageNames}
Note: PackageNames/DefectID are case-sensitive.
Commands:
-help (-h) : Print psu command usage
-query (-q) : Print list of package(s) available in the specified source location
(default source location is installed repository of the product).
-install (-i) : Install packages.
-uninstall (-u) : Uninstall packages from the repository.
-download (-d) : Download Device packages for the specified product(s).
-software (-s) : Download Software packages for the specified product(s).
-pointpatch (-pp) : Download Point Patches for the specified product(s).
-pkgDependents (-pdep) : Print list of base package(s) for the specified package(s) present in the source location
-pkgversion (-pver) : Print the versions of the specified package(s) present in the source location
Options:
-p product : Product for which download/query/install/uninstall is carried out.
The specified Product must be registered with PSU during installation.
-src dir : Source location of packages.
-all : Select all packages from the source location.
-dst dir : Destination location for download of packages.
-noprompt : flag which turns off the prompting for restart of daemon services during install/uninstall
Valid options for (-p):
cm ( Network Topology Layer 2 Services and User Tracking )
lmsportal ( LMS Portal )
rme ( Inventory Config And Image Management )
dfm ( Fault Management )
ipm ( IPSLA Performance Management )
cvw ( CiscoView )
entory ( Config And Image Management ) <-- This is strange
upm ( Device Performance Management )
Anybody having a glue, idea, whatever???
Thanks in advance
Lothar
07-24-2012 11:57 PM
Hi all,
solution from Cisco TAC
During install we got a corrupted file /opt/CSCOpx/lib/classpath/com/cisco/nm/xms/psu/conf/tag.properties
with exchanging with an uncorrupted one PSUCli.sh works as expected
