LMS 4.2.1 - Tunnels missing in Topology view
savic.marija
Beginner
Beginner
I have problem with topology view in LMS 4.2.1, it doesn't show the tunnels connecting branches, though both devices are shown in sh cdp neighbour command output. If I choose Show Devices in Admin > Collection Settings > Data Collection, it is showing cdp neighbours correctly.
Any ideas why campus manager is not drawing tunnels?
Thanks!
Marija
4 REPLIES 4
Michel Hegeraat
Rising star
Rising star
This once worked in my lab using LMS 3.0 or LMS 2.6
The key there was that cdp was enabled explicitly on both sides in the interface config. The tu interfaces had a CDP enable command.
The 'sh cdp' on both sides show the other router behind the tunnel interface.
You have this too?
Maybe cisco decided not include certain interface types anymore rather then check for CDP neighbors....would be silly if that was the case though.
Cheers,
Michel
Yes, cdp is enabled in on tunnels:
WAN2_c3945#sh cdp neig
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
Rtr-Svilajnac-c2901.srpskad.domen
                 Tunnel1            153            R S I  CISCO2901 Tunnel1
Rtr-Bacvanska-c2901.srpskad.domen
                 Tunnel1            138            R S I  CISCO2901 Tunnel1
Rtr-Svilajnac-c2901#sh cdp neigh
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
WAN1-c3945.srpskad.domen
                 Tunnel0            130           R T S I CISCO3945 Tunnel0
WAN2_c3945.srspkad.domen
                 Tunnel1            171           R T S I CISCO3945 Tunnel1
WAN3_c3945.srpskad.domen
                 Tunnel2            162            R S I  CISCO3945 Tunnel2
Sw-Svilajnac-c2960.srpskabanka.rs
                 Gig 0/1            168             S I   WS-C2960- Gig 0/2
WAN2_c3945#sh run interface tunnel 1
Building configuration...
Current configuration : 332 bytes
interface Tunnel1
bandwidth 1000000
ip address 172.20.102.1 255.255.255.0
no ip redirects
ip mtu 1420
ip nhrp map multicast dynamic
ip nhrp network-id 11
ip tcp adjust-mss 1360
delay 10
qos pre-classify
cdp enable
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel protection ipsec profile DMVPN
end
Rtr-Svilajnac-c2901#sh run interface tunnel 1
Current configuration : 383 bytes
interface Tunnel1
bandwidth 1000000
ip address 172.20.102.120 255.255.255.0
ip mtu 1420
ip nhrp map 172.20.102.1 192.168.255.166
ip nhrp map multicast 192.168.255.166
ip nhrp nhs 172.20.102.1
delay 50
cdp enable
tunnel destination 192.168.255.166
end
Marija
The only difference I see with what I had back then is that I did not use the tunnels for the actuall traffic.
My tunnels were just there to 'connect' via CDP the remote sites while MPLS was routting the real traffic.
My guess is that the TU interface type is no longer included. Best ask cisco TAC about this.
There are various xml files that tell campus what it should do.
Cheers,
Michel
I got the answer from TAC engineer that DMVPN tunnles are not supported in topology view and that we can raise the request for enhancement to support this.
Marija
