LMS 4.2.2 SNMPV3 Wrong Privacy Algorithm
Wolfgang Maier
we use LMS 4.2.2 to manage our Cisco devices. At the moment all devices are managed with snmpv2.
I´ve picked one Catalyst 2960-24TT-L Version 12.2(25)SEE3 and configured snmpv3
Here´s the output of show snmp user:
User name: ciscoworks
Engine ID: 8000000903000022BD29EF40
storage-type: nonvolatile        active
Authentication Protocol: MD5
Privacy Protocol: DES
Group-name: LMS
Now, in LMS under Admin->Network->Device Credentials Settings-> i created a new credential set "snmpv3" with the correct user/password and following settings:
AuthPriv (enabled)
Auth Algorithm MD5
Privacy Algorithm DES (because the 2960 12.2(25)SEE3 doesn´t support any other alorithm).
I´ve edited the credentials and assigned the new set to that device. Now to test the snmpv3 credentials i´ve started an Device credential verification job an chose snmpv3 only. But every time the job failes with the error
Wrong Privacy Algorithm.
Can someone haelp me ou with this issue? Thank you.
Wolfgang Maier
OK, got it to work. The snmpv3 credential set didn´t overwrote the snmp options. Now everything works
