LMS 4.2.3 License problem
gianpiero.viola
Hi all,
I have a Cisco prime Infrastructure 1.2 that include Cisco prime NCS 1.2 and Cisco Prime LMS 4.2.
On License menu of LMS system I have that:
But when I go to open menu: Monitor->Monitoring tools -> Fault Monitor
Iget the following pop-up
I wonder if it is normal.
thanks to all and Have happy 2013
tira li
Hi Gianpiero,
       Do you try to reimport the license and restart the daemon?
       In addition, I just wonder that what LMS-COMP license use for?
happy new year
tira li
Hi Gianpiero,
happy new year
Hi Tira,
thanks for you support,
Unfortunately I can't test it until next week.
The license LMS-COMP was already pre-loaded immediately after installation
Bye
Hello Tira,
Good News,
fortunately, the problem is solved by a reload of the virtual machine before I could try to restart only the service, then I think that your solution could be fine too.
thanks
