03-14-2015 07:58 AM
Hi Team,
Ciscoworks LMS deamon manger failed start with below error
Error:
The service is not responding to the control function.
More help is available by typing NET HELPMSG 2186.
Below is the event i found the Eventviewer
The Cisco Prime Daemon Manager service failed to start due to the following error:
The service did not respond to the start or control request in a timely fashion.
Any suggestion on this??
Channa
03-14-2015 08:18 AM
Check the swap configuration (swap virtual memory on the installation drive of the LMS). Configure Swap manually.
- Ashok
Please rate the post or mark as correct answer as it will help others looking for similar information
03-14-2015 08:47 AM
Hi Ashok,
Thanks for your reply.
i have made sure the swap is configured and in place.
Physical Memory : 16 GB
Swap memory : 32 GB
I also tried to resetting the CASUSER and added to the administrator group. but no luck.
Please suggest.
Channa
03-14-2015 09:30 AM
Ok! check for below as well!
- Certificate issue:Try Recreating the certificate
- Apache process unregistered by mistake and that prevents the Daemon manager from coming up. Try Register the Apache process
- some times md.properties may also gone corrupt.
if you still face issue, you can open a TAC case for through analysis.
- Ashok
03-14-2015 09:30 AM
Hi Ashok,
I also tried by recreating the certificate also but it didn't help.
can you brief how to register the Apache process??
Channa
03-17-2015 10:33 AM
Not sure why you want to register the Apache process alone when the entire LMS services are not starting.
Please check NMSROOT/logs/syslog.log and share the error you see in it, when you try to start the services.
Also, try to make user casuser a member of administrators group and also make sure it is not disabled. You can access the Local users and groups manager wizard to check this (start > run > lusrmgr.msc).
-Thanks
Vinod
03-18-2015 03:38 AM
Hi Vinod,
i have checked the casuser is in enabled.
want to know the LMS server added to the domain recently, adding the server into domain going to affect the LMS services ??
Channa
