03-05-2014 01:59 AM
Can some one please advise.
I am have an issue with LMS where it is not fully comming up. I have shut down and restarted several times, with the latest giving me the following result within the macuhic.log, attached also PDSHOW :
Informational: Starting Cisco Process Manager communication thread
log4j:WARN No appenders could be found for logger (org.apache.activemq.transport.WireFormatNegotiator).
log4j:WARN Please initialize the log4j system properly.
CtrlPlaneListener -- Waiting to receive messages! Topic --> ut.uhic.mac
Intializing the Controler 1 = log Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.LogCtrl
messages will remian logged to file: macuhic.log
Intializing the Controler 2 = cblog Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.CBLogCtrl
Intializing the Controler 3 = gen Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.GenericCtrl
Intializing the Controler 4 = vqueue Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.VQCtrl
Intializing the Controler 5 = db Pkg = com.cisco.nm.cm.ut.uhic.mac.ctrls.DBUpdateCtrl
Executing IDM Procedures
Failed to create Tables. Transaction Rolled back
: com.sybase.jdbc2.jdbc.SybSQLException: SQL Anywhere Error -110: Item 'getAuthenticatedUsers_ACS' already exists
Loading locationDetails jars
Setting Java path in windows
com.sybase.jdbc2.jdbc.SybSQLException: SQL Anywhere Error -110: Item 'locationDetails.jar' already exists
at com.sybase.jdbc2.tds.Tds.processEed(Tds.java:2884)
at com.sybase.jdbc2.tds.Tds.nextResult(Tds.java:2206)
at com.sybase.jdbc2.jdbc.ResultGetter.nextResult(ResultGetter.java:69)
at com.sybase.jdbc2.jdbc.SybStatement.nextResult(SybStatement.java:220)
at com.sybase.jdbc2.jdbc.SybStatement.nextResult(SybStatement.java:203)
at com.sybase.jdbc2.jdbc.SybStatement.updateLoop(SybStatement.java:1702)
at com.sybase.jdbc2.jdbc.SybStatement.executeUpdate(SybStatement.java:1685)
at com.sybase.jdbc2.jdbc.SybStatement.executeUpdate(SybStatement.java:431)
at com.cisco.nm.cm.ut.ctrlplane.ctrls.DBCtrl.medianetQuery(DBCtrl.java:100)
at com.cisco.nm.cm.ut.ctrlplane.ctrls.DBCtrl.initializeDBSchema(DBCtrl.java:78)
at com.cisco.nm.cm.ut.ctrlplane.ctrls.DBCtrl.init(DBCtrl.java:56)
at com.cisco.nm.cm.ut.uhic.mac.ctrls.DBUpdateCtrl.<init>(DBUpdateCtrl.java:53)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at com.cisco.nm.cm.ut.ctrlplane.EntityCtrlMgr.initialize(EntityCtrlMgr.java:497)
at com.cisco.nm.cm.ut.ctrlplane.EntityCtrlMgr.initControlers(EntityCtrlMgr.java:529)
at com.cisco.nm.cm.ut.ctrlplane.EntityCtrlMgr.main(EntityCtrlMgr.java:898)
The number of DB connections:2
class com.cisco.nm.cm.ut.db.DBConnectionCreated new Database connection [hashCode = 10217370]
class com.cisco.nm.cm.ut.db.DBConnectionsuccessfully connected to db-url jdbc:odbc:cwsi
Creating Threads :8
Intializing the Controler 6 = filter Pkg = com.cisco.nm.cm.ut.uhic.mac.ctrls.FilterCtrl
Intializing the Controler 7 = dec Pkg = com.cisco.nm.cm.ut.uhic.mac.ctrls.DecodeCtrl
Intializing the Controler 8 = tpm Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.TPMCtrl
Created TPM
Intializing the Controler 9 = sktsend Pkg = com.cisco.nm.cm.ut.uhic.mac.ctrls.SktSenderCtrl
Intializing the Controler 10 = skt Pkg = com.cisco.nm.cm.ut.ctrlplane.ctrls.SocketCtrl
Started Socket Listener
class com.cisco.nm.cm.ut.db.DBConnectionClosed Database connection [hashCode = 10217370]
03-05-2014 05:39 PM
Hi Ian,
Thanks for the details.
Enable the Debugging for Daemon Manager as below :
1. Go to Run and issue the regedit command.
2. Go to this key and add the entries:
HKEY_LOCAL_MACHINE\Software\Cisco\ResourceManager\CurrentVersion\Environment
Values:
PX_DBG=1
PX_MY_DEBUG=1
PX_MY_TRACE=1
PX_DBG_LEVEL=1
Note: for adding a value:
* Right click on the Environment Right side and choose New > String Value.
* Provide the name of the value
* Right click on the value name and choose Modify.
* Provide the value 1 and click on OK
Close the Regedit.
3. Stop the daemon manager
From the CLI:
> net stop crmdmgtd
4. Restart the daemon Manager by issuing:
> net start crmdmgtd
wait for the 4-5 min ,collect the log file
5. Send me the following file: dmgtDbg.log (NMSROOT/CSCOpx/log)
IMP: As soon as you collect the dmgtDbg.log file , Remove those 4 Entries from REGISTRY.
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****.
03-06-2014 01:43 AM
Hi Afroj,
The intresting point is I can not find the Key
In the Registry !!!
There is no
03-06-2014 02:46 AM
Hi Ian,
look under:
HKEY_LOCAL_MACHINE\Software\ Wow6432Node
Thanks-
Afroz
03-06-2014 03:10 AM
03-06-2014 03:13 AM
Hi Ian ,
file does not contail enough information.
after enabling the debug .. you need to restart the daemon manager ..
after you have logs ..remove the PX entries from registry
Thanks-
Afroz
03-06-2014 03:55 AM
Hi Afroj,
The first file was after the Server had rebotted, after adding the Debug options and had started up on its own.
I have now shut down the processes again and restarted.
From what I can see the system has now come up fully !!!
And is now running normally.
I have attached the debug file and pdshow for you to look at.
I will now delete the debug reg settings.
03-06-2014 05:16 AM
Hi Ian,
Thanks for sharing the logs.from the shared logs , I did not find any root cause of the issue.
looks like some Ports was in a blocked state ,which would have released after several restart.
from the pdshow output , I can all the processes are running fine
Thanks-
Afroz
03-06-2014 05:59 AM
Hi Afroj,
I would like to thank you for assiting and providing the help which finally resolved the issue.
Rgrades
Ian
03-06-2014 06:15 AM
I am really glad to know everything is fine.
Thanks-
Afroz
