LMS 4.2.4, problem Software distribution 3560 switches
dbelno
i am running LMS 4.2.4 and i have problems with software distribution.we have about 1000 switches and routers. i receive the error message: "Error loading image to Flash. See C:\PROGRA~2\CSCOpx\files\rme\jobs\swim\5755\sw0-linz-dl35_telnet.log for the output from the device on which the image transfer failed.
Image Copy Operation Failed". But the image is uploaded to the switch correctly.
This are the timers i have configured:
SNMP-Settings:
Number of retries: 2
Timeout interval: 2
Other Settings:
Telnet Timeout: 36
TFTP Timeout: 120
Read Delay: 200
Transport Timeout: 120000
Login Timeout: 10000
Tune Sleep: 5000
Delay After Connect: 3000
Can anyone help me. I cant find any documents about timer setting for 3560 switches.
Your flash shows the same IOS which you are upgrading :
Copying c3560-ipbasek9-tar.122-55.SE8.tar from Software Repository to tftp-specific directory.
Directory of flash:/
    2  -rwx        3096  Feb 25 2014 09:34:57 +01:00  multiple-fs
    3  -rwx       13524   Mar 3 2014 16:06:29 +01:00  vlan.dat
    5  -rwx       41821  Feb 25 2014 09:34:57 +01:00  config.text
    8  drwx         192  Mar 13 2014 12:17:06 +01:00  c3560-ipbasek9-mz.122-55.SE8
    6  -rwx        2615  Feb 25 2014 09:34:57 +01:00  private-config.text
So the upgrade is successful, but job result shows failed.
It seems to be timeout issue. Increase Telnet timout to 800 or 1000 and Read Delay to 1000.
Also, check if your device has long timeout for Telnet/SSH session. Increase it for testing.
It is usually because .tar images take a lot of time in getting copied and than while being extracted.
-Thanks
Vinod
**Encourage Contributors for free. RATE them :) **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
5 Replies 5
AFROJ AHMAD
Increased Telnet timeout :
Admin > Network > Timeout and Retry Settings > Inventory/Config Timeout and Retry
Settings
timeout to 60
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
i changed timeout to 60 .....same result.
changed to 600.....same result.
Processing Device : sw0-linz-dl35
Start Time : Thu Mar 13 12:11:25 CET 2014
Device is locked for exclusive access.
The supported protocols for image transfer are: TFTP
Connecting to the device using SSH...
Connected successfully.
Sufficient free space is available on flash to copy the image.
Retrieving configuration file from the device...
Current device config is copied to C:\PROGRA~2\CSCOpx\files\rme\jobs\swim\5767\sw0-linz-dl35_Config
Checking if HTTP server is enabled on the device...
Http Server is not enabled, will continue with Software Upgrade Operation.
Copied successfully to C:/PROGRA~2/CSCOpx/tftpboot/rep_sw_2380333825594591120
Loading image file to flash device : rep_sw_2380333825594591120 --> flash:c3560-ipbasek9-tar.122-55.SE8.tar using TFTP
Error loading image to Flash. See C:\PROGRA~2\CSCOpx\files\rme\jobs\swim\5767\sw0-linz-dl35_telnet.log for the output from the device on which the image transfer failed.
Device is unlocked.
Device Upgrade Result : Failed
Output from Switch:
I think this is not the right parameter
BR
Norbert
Enabled the debugging for SWIM ( admin >debug settings)
re-run the SWIM job.
send me the below log file:
swim_debug.log
and job log  ( NMSROOT/CSCOpx/files/rme/jobs/SWIM) > look for JOB ID no. of the recent job
Thanks-
Afroj
-Thanks
Vinod
hi,
i tried with timout 800 and it worked
thanks
Norbert
