Michael_Fink_3
Beginner
LMS 4.2.4 showing Link Trunk/NonTrunk Mismatch
i have installed our LMS 4.2.4 and have discovered all our switches.
now i see under Discrepancies the Error "Link Trunk/NonTrunk Mismatch"
The reported switch is connected via vpc to 2 N7K´s and the link works fine, so i don´t understand this Error.
here is the Config of the Nexus Ports:
N7K1:
interface Ethernet3/26
  description vPC to switch1
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 91-92,94,96,99,839
  spanning-tree port type normal
  udld disable
  channel-group 34 mode active
  no shutdown
interface port-channel34
  description vPC to switch 1
  switchport
  vpc 34
N7K2:
  switchport
  udld disable
  no shutdown
  switchport
  vpc 34
And here the config of the switch (2960s):
interface GigabitEthernet1/0/49
description Trunk to n7k1
switchport trunk allowed vlan 91,92,94,96,99,839
ip arp inspection trust
mls qos trust dscp
no vtp
channel-group 1 mode active
ip dhcp snooping trust
end
interface GigabitEthernet1/0/50
description Trunk to n7k2
mls qos trust dscp
no vtp
end
interface Port-channel1
no vtp
and vtp is turned off (version 3, mode off).
do anyone has information regarding this error?
thank you!
kind regards,
Michael
4 REPLIES 4
AFROJ AHMAD
Hi ,
I would suggest to Run the DATA Collection for that device Only from Topology MAP.
after the data collection is complted run a new user tracking Acquistion and check the status again.
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
i tried this, but it didn´t help.
i also have connected a 3750x in the same way to the N7K´s, there is no issue.
the only difference of the configuration is, that i have to enter "switchport trunk encapsulation dot1q" for the Uplink Ports / Portchannel.
for the same switch (2960s) and the same ports i have also the discrepancy "Trunk  negotiation across VTP boundary"
anyhow, vtp is turned off:
VTP Version capable             : 1 to 3
VTP version running             : 3
VTP Domain Name                 : Access-XYZ
VTP Pruning Mode                : Disabled
VTP Traps Generation            : Disabled
Device ID                       : 1ce6.c788.e400
Feature VLAN:
VTP Operating Mode                : Off
Number of existing VLANs          : 11
Number of existing extended VLANs : 0
Maximum VLANs supported locally   : 255
Feature MST:
VTP Operating Mode                : Transparent
Feature UNKNOWN:
is there really a configuration issue, or that are only wrong messages from LMS?
kind regards,
Michael
Hi Michael,
It looks like a wrong message from the LMS.
what happened when you click on FIX  ? did the discrepancies occured again after clicking  on fix.
Thanks-
Afroz
Hi Afroz,
i clicked on FIX, but i don´t do the FIX of LMS, LMS want´s to set the Ports on the N7K´s and on the switch to "switchport mode dynamic desirable" - i think that is not a valid solution :-)
is it possible, that there is is simply a incompatibility of LMS between a N7K vPC and a 2960s?
there are also some faults reported regarding vtp - the only thing, what i want, is, that vtp is deactivated :-)
so i think, the vtp configuration is ok, so far.
do you have any recommends regarding this?
kind regards,
Michael
