02-19-2016 05:04 AM
CiscoView in LMS 4.2.5 doesnt show a network module of a switch:
The module that should be displayed is C3KX-NM-1G:
Do you have the same experience or am I missing some packages?
Thanks in advance!
Marek
Solved! Go to Solution.
02-22-2016 04:23 PM
OK. From what you posted it looks like a bug in the CiscoView package as it is obviously not properly retrieving the inventory so that it can properly display the module and associated ports.
I'd recommend opening a TAC case.
02-21-2016 08:54 AM
Check your CiscoView package updates.
I though support for that network module in the 3560-X has been out for a while (since 4.0) but it's possible you may not have updated your CiscoView packages for a long time.
Also make sure your switch is recognized as having the SNMP OID of 1.3.6.1.4.1.9.1.1227. Sometimes an IOS update can change that and give LMS problems of not correctly recognizing a device.
Oddly when I check the CiscoView updates download site I don't see the 3650 at all - all of the other Cat 3k's yes but not that particular line.
https://software.cisco.com/download/release.html?mdfid=284259296&flowid=37207&softwareid=282812296&release=DtShare(1.22)&relind=AVAILABLE&rellifecycle=&reltype=latest
02-22-2016 02:13 PM
02-22-2016 04:23 PM
