Highlighted
LMS 4.2.5 topology view is not updating the devices status when disconnected
Dear,
I have installed LMS 4.2.5 and discovered the devices and they are in reachable state, Also a data collection was done and device management was altered.
Everything is okay except the topology view that shows the devices in green state, but when I try to disconnect any device it is not reflected on the topology view as marking the device in red or the link.
here is the snmp commands that I have used:
mp-server group snmpgroup v3 auth
snmp-server user lmsuser snmpgroup v3 auth md5 lmsuser123
snmp-server group snmpgroup v3 auth write v1 notify v1
snmp-server host 172.20.250.102 traps version 3 auth lmsuser
snmp-server group snmpgroup v3 auth notify v1
snmp-server group snmpgroup v3 auth context vlan-250 notify v1
snmp-server group snmpgroup v3 auth context vlan-1 notify v1
snmp-server group snmpgroup v3 auth context vlan-2 notify v1
snmp-server group snmpgroup v3 auth context vlan-3 notify v1
snmp-server group snmpgroup v3 auth context vlan-4 notify v1
snmp-server group snmpgroup v3 auth context vlan-8 notify v1
snmp-server group snmpgroup v3 auth context vlan-9 notify v1
snmp-server group snmpgroup v3 auth context vlan-10 notify v1
snmp-server group snmpgroup v3 auth context vlan-15 notify v1
snmp-server group snmpgroup v3 auth context vlan-18 notify v1
snmp-server group snmpgroup v3 auth context vlan-20 notify v1
snmp-server group snmpgroup v3 auth context vlan-25 notify v1
snmp-server group snmpgroup v3 auth context vlan-33 notify v1
snmp-server group snmpgroup v3 auth context vlan-100 notify v1
snmp-server group snmpgroup v3 auth context vlan-128 notify v1
snmp-server group snmpgroup v3 auth context vlan-612 notify v1
snmp-server host 172.20.250.102 version 3 auth lmsuser
snmp-server enable traps
snmp-server source traps vlan 250
Any idea.
Thanx in advance
7 REPLIES 7
Highlighted
Hall of Fame Guru
Topology view is not a real time status map. It being updated will depend on your ANI polling cycle.
The near real time display would be in the alarm and/or syslog browsers.
Highlighted
dear marvin,
Thank you for your reply, but i have disconnected some devices and waited for a really long time with no effect.
I can see from the topology view when i navigate to device dashboard that the device is not reachable after 5 minutes or so but it is not reflected at all on the view.
I am afraid that there is a compatibility issue with the JAVA version or the Internet Explorer.
Highlighted
You have to go to:
right click on the device in the topology view and "add device to critical poller"
Then go toL
Admin > Collection Settings > Data Collection > Data Collection Critical Devices Poller
and set your time, the min is 5 secs
Highlighted
Thank you for your reply.
Now after i followed your advice, The devices are discovered as reachable and not reachable very fast, But they wont show up automatically on the topology view.
If i closed the topology view and re open it, it works, but only if i closed and re-opened the veiw.
Maybe i have a java problem or a browser problem, I have i.e 11.0 and mozilla 23 as written in the datasheet.
and the java is 7u21 downloaded from the LMS.
Any idea dear.
Highlighted
Topology view worked perfectly in ver 2.5, but when they went to ver3 and beyond it has never worked right since and then you throw the java nightmare on top of it and it just gets worse.
The only time I go into topo view is if I want to quickly see where spanningtree has blocked ports, other than that I haven't found much use for it.
Good luck
Highlighted
Please help on this issue. I am also facing same kind of issue. Device and link failures are not reflecting on Topology until it reopens.
How to change ANI polling cycle?
Jomin
Highlighted
Hi Jomin
Topology is not design to provide real time status, it will update base on the pollers above mentioned and the only way to reflect that on the map is by reopening it, is not a problem with java or LMS, is just by design.
Content for Community-Ad
