10-18-2013 09:36 AM
I tend to get alarms/events that I really would rather not see. For instance, I have a voice router that consantly shows BACKUPACTIVATED, which is the intended use of the ports. Also I have another alert/event for CARDS whose Status is NOT PRESENT. I'm not really concerned about these, but I'm sick of clearing them manually all the time. Is there a way to prune or weed these out so I no longer have to see them in the fault/event managers?
10-18-2013 09:12 PM
check if BACKUPACTIVATED and NOT PRESENT is selected under EVENTSET :
Admin > Network > Notification and Action Settings > Event Sets
If yes uncheck them
Thanks-
Afroz
[Do rate the useful post]
10-23-2013 09:24 AM
They aren't checked...actually nothing was under Event Sets. So this has got to be something else. Thanks for trying though
10-24-2013 01:40 AM
If you have nothing selected by default , you will be notifed for every event.
creat a Event set with the Events you are interested in and use that event set ( lets say A) in the Notification Group and this should work.
Read the below document for more understanding of the Alarm and event :
Thanks-
Afroz
