LMS 4.2 ANIserver problem
cwallin
Beginner
Beginner
Hello, we are running LMS 4.2.2 and our Topology maps have stopped working and I noticed that the ANIserver process is down.
By tailing the /var/adm/CSCOpx/log/dmgtd.log i got the messages below, any idea whats going on?
A shutdown of LMS + reboot did not help.
BR /Crille
Jan  9 12:39:12 xxx dmgt[3318]: #3007:TYPE=INFO:Started application(ANIServer) "/opt/CSCOpx/lib/jre/bin/java -Xbootclasspath:/opt/CSCOpx/lib/jre/lib/jsse.jar:/opt/CSCOpx/MDC/tomcat/webapps/campus/WEB-INF/classes:/opt/CSCOpx/MDC/tomcat/webapps/campus/WEB-INF/lib/log4j.jar:/opt/CSCOpx/www/classpath/jacorb.jar:/opt/CSCOpx/lib/jre/lib/rt.jar:/opt/CSCOpx/lib/jre/lib/jce.jar -Xminf0.1 -Xmaxf0.1 -Djava.class.path=/opt/CSCOpx/campus/lib/classpath/castor-1.2.jar:/opt/CSCOpx/campus/lib/classpath/commons-logging-1.1.1.jar:/opt/CSCOpx/campus/www/classpath/jndi.jar:/opt/CSCOpx/campus/www/classpath/providerutil.jar:/opt/CSCOpx/lib/jre/lib/ext/dnsns.jar:/opt/CSCOpx/campus/lib/classpath:/opt/CSCOpx/campus/www/classpath:/opt/CSCOpx/lib/classpath:/opt/CSCOpx/www/classpath:/opt/CSCOpx/MDC/tomcat/webapps/campus/WEB-INF/lib/ctm.jar:/opt/CSCOpx/lib/classpath/cmfjms.jar:/opt/CSCOpx/MDC/tomcat/webapps/campus/WEB-INF/lib/xalan.jar:/opt/CSCOpx/MDC/tomcat/webapps/campus/WEB-INF/lib/xerces.jar:/opt/CSCOpx/lib/jre/lib/jsse.jar:/opt/CSCOpx/lib/jre/lib/jce.jar:/opt/CSCO
Jan  9 12:39:16 xxx dmgt[3318]: #3021:TYPE=INFO:Died method called for process (ANIServer, pid=10851).#015
Jan  9 12:39:16 xxx dmgt[3318]: #2135:TYPE=WARNING:Stale socket -1 while establishing connection with ANIServer: Bad file descriptor. #015
Hi Crille,
Aniserver.properties looks fine.
what I can suggest is to stop the daemon manager  (/etc/init.d/dmgtd stop)
check if any stale process is running
run this command : ps -ef | grep "CSCO"
if you find any process running other than root . Manually  kill it and start the daemon manager (/etc/init.d/dmgtd start)
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
5 Replies 5
AFROJ AHMAD
Hi ,
Share the below files:
ANIServer.properties and
ANIServer.properties.orig
location : /opt/CSCOpx/campus/etc/cwsi/ANIServer.properties'
Thanks-
Afroz
Vinod Arya
Topology is dependent on ANIServer and it may not work if it goes down. Better is you share aniserver.properties and aniserver.log and ani.log from your server for more insight.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hello and thank you for a fast response from you both!
Attached is a zip with these files:
/opt/CSCOpx/campus/etc/cwsi/ANIServer.properties.orig
/var/adm/CSCOpx/log/ani.log
I could not find a aniserver.log, guessing that only exists in a windows installation?
Br /Crille
Hi Crille,
Thanks-
Afroz
Hello, tried a stop / start but EssentialsDM stalled, tried another stop /start and then it woke up.
So in fact a tripple restart and its working again
Thank you again for fast replies!
BR /Crille
Recognize Your Peers
