LMS 4.2 Applications missing from Software Center
jedavis
Level 4
Level 4
I have a problem with LMS 4.2.4 Software center on Win2K8.  I have been trying to download device updates and the only product listed in software center has been:
Inventory Config And Image Management
It seems like this happened to me before and I opened a TAC case and got the list of products back but I can't seem to locate the case history.  To top it off my LMS support contract is in limbo due to some administrative glitch and I am waiting for my account team to sort it out.  Meanwhile I have just installed some relatively new products (3850, 4500-X) and LMS doesn't seem to recognize these completely.
The list of apps seems to be stored in the NMSROOT\lib\classpath\com\cisco\nm\xms\psu\conf\tag.properties.  I stumbled accross a tag.pl script in the bin directory that modifies this file.  So I searched in vain for the proper contents for the tag.properties file.  In the end I just issued the following sequence to get common services back:
cd <NMSROOT>\lib\classpath\com\cisco\nm\xms\psu\conf
perl D:\Software\CSCOpx\bin\tag.pl tag.properties -a "cmf:Common Services"
So I am not sure why a perl script to modify the tag.properties file is necessary since it just seems to append the specified product to the end of the file. In any event I then went to
Admin > System > Software Center > Device Update
and sure enough CMF appears and I am able to check for and install device updates for it.  However, I still seem to be unable to perform UT collection for the 3850 stack which is what I am really after.  So does anyone know what product I need to add and get updates for in order to get user tracking working?  In other words, what is the output of
psucli.bat -h?
-Jeff
Hi Jeff,
looks like tag.prop is corrupted.
it should have the below content :
ipm:IPSLA Performance Management
cmf:Common Services
lmsportal:LMS Portal
cvw:CiscoView
rme:Inventory Config And Image Management
dfm:Fault Management
lms:LAN Management Solution
upm:Device Performance Management
cm:Network Topology Layer 2 Services and User Tracking
Is this a new Installed ? if yes share the Installed.log
if you have good backup ,then try retstoring it.
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
5 Replies 5
AFROJ AHMAD
Hi ,
Check the screen shot . Are all the Application checked ?
Make sure they are checked.
psucli.bat -h?   is the help command for Psucli.
chekc this link:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/user/guide/admin/swcenter.html
Thanks-
Afroz
Hi Afroj,
Yes all of the applications are checked in the Device Allocation Settings.  The problem seems to be that the tag.properties file is corrupt.  It currently just contains these 2 lines, and I added the second one.
cmf:Common Services
Consequently my device update screen appears as in the attachment.
-Jeff
Hi Jeff,
cmf:Common Services
cvw:CiscoView
Thanks-
Afroz
Hi Afroj,
Interestingly enough once I minimized all the windows I had open I found a tag.properties file on the Windows desktop dated 3/5/2013.  This may have been a file that TAC provided last time I had this problem.  I popped that into the conf directory and now I see all the products in the device update window.
Thanks for your help!
-Jeff
Great
Thanks-
[Do resolved the thread ,if it has helped you ]
