lms 4.2 didn't notify me when a Power supply stops working
Ibrahim Jamil
Level 6
Level 6
Hi Guys
i have router 7200 , one of its power supply stops working , but lms 4.2 doesn't notify me?pls help to solve this issue
thanks
ibrahim
6 Replies 6
Marvin Rhoads
Ibrahim,
Is the 7200 being managed by LMS? Please confirm:
1. The device is setup to be managed by fault (reference)
2. The device credentials are correct (using the tool in Device Center)
3. That you have logging and snmp server destination = LMS server on your router.
#3 is not necessary but optional. If #1 and #2 are correct, Fault management should pick up the failure.
Hi Marvin
thanks for ur reply
the 7200 managed by LMS
thanks
Ibrahim
That you are seeing it in CiscoView does not mean it is managed in Fault Management. Have you checked the steps I recommended above, specifically Step 1?
Hi Marvin
i have configured as you provided , but i dont see the error related to the power supply  even in the fault view
thanks
Ibrahim,
If the Fault had been acknowledged, either intentionally or inadvertently, it would be moved out of the Fault view and only appear in the Events listing. The same thing would happen if the fault condition clears.
That's the only opther thing I can think of given that you've verified everything else.
thanks marvin,i will keep monitor
